Hood
I am obsessed.
- Carnoustie, Scotland
Centre slit with a slitting discYou'd struggle to centre pop the bits, they're hardened, I tried and blunted 2 centre punches![]()
VandalCentre slit with a slitting disc![]()
This is exactly what my Triumph has - you can quickly angle the toolpost to suite the job and the tool. Would like a qtp for it though, but that size they are expensive...That's ok, a lot of bigger lathes just have a tee slot in the compound slide for the toolpost, it doesn't NEED to be that huge great lump of a centre post. You'd get away with a simple stud for a QCTP, as long as it's flat to the deck then it will be rigid.
Did a quick vid to show the capto tooling and how easy it is to swap out.Capto - Please explain,I'm lost relatively new to this game
Put it so wellWhat is it with some folk on here. Not happy unless tempting us with stuff we didn't know about, but now want?![]()
In all honesty I don't think it takes much to tempt youWhat is it with some folk on here. Not happy unless tempting us with stuff we didn't know about, but now want?![]()
Check the carriage lock isn't on a bit. It's a square head stud on the front, tailstock end of the apron. Actuates a tapered bit underneath against the vee way.That's the toolpost and compound slide rebuilt and wow what a difference turning it really smooth dovetail slid in on an oil slick where as when I was taking it apart I needed a rubber mallet.
Can easily turn one handed nice and accurate and gibs nipped up gives a little more resistance but still real smooth.
Now in oil and paper to keep crap off it and stop surface rust while I get the cross slide and maybe apron sorted as cross slide is quite free at the moment but apron is really stiff moving by hand not sure why.
View attachment 317555View attachment 317554
Not following you there , opposite side to the gibsCheck the carriage lock isn't on a bit. It's a square head stud on the front, tailstock end of the apron. Actuates a tapered bit underneath against the vee way.
He is meaning the apron being stiff as you wind along the Z axis to and from the chuck. On the top of the saddle there will be a square head bolt which locks the saddle on the ways.
Most likely muck between part 12 and the saddle which stops it pulling up enough. If it is worn, which I think unlikely unless some monkey has been power feeding with it locked, then you may have to skim a bit off the top of part 12...Funnily enough, mine doesn't work, won't lock up at all so it needs stripped down.
Not a huge amount to test at the moment...
