Olderisbetter
- Wolverhampton
Fixed the coffin, all the UV LEDs had gone pop when the wrong voltage was used to power them
Gas gas.Is that an early Montesa / Honda?
Eat fewer beans.Gas gas.
One of these bad boys is on my hit list one fine dayToday I attacked the cold saw, made a bracket and fitted the new to me suds pump, rewired, fitted a new tap and repiped it.
I bought a set of disc harrows last year, on the basis the price was he same as paying the contractor to do the prep work for summer feed. That plan didn't quite work - who would have thought tractor salesmen are related to car salesmen? They were supposed to be running, but having had to reseal the hydraulic cylinder and new hoses and brazing a fitting, I think they may have been economical with the truth...
I should have gone over them in winter, but anyway, finish the first paddock and a bearing collapses. The nut on the end of the shaft that holds the disks in palce came undone, the whole lot shifted sideways, ate the bearing and then started on the cast iron spacer. No bearings available easily so I have had to mail order some for this week,
The bearing hanger had seen better days and some past abuse, being bent 40mm and ripping the welds, so while it was apart, I put them in the forge and gave it a talking to with a 4lb hammer.
It will live again, but the contractor has finished the job again this year.
View attachment 314150View attachment 314151View attachment 314152View attachment 314153View attachment 314154
View attachment 314146 View attachment 314147 View attachment 314148 View attachment 314149
Yes. But I haven't got the banjo, the gears nor a tailstock.That's nice! Is the shaft on the back for differential indexing?
You could made the gears if you had a dividing head.Yes. But I haven't got the banjo, the gears nor a tailstock.
I paid £90
4"You could made the gears if you had a dividing head.
Looks good for ninety quid, what size is the chuck?
Is it aluminium? That will be your issue with g101I've hopefully repaired my ultrasound tank, time will tell.
About a year ago it started tripping the RCD, I took it apart to see what was going on and the PCB was soaked, there was a pinhole in the tank.
Looking closely, there's hundreds of tiny pits. I've never had any proper ultrasonic fluid, I just use whatever's handy, usually MucOff or G101 but sometimes caustic soda, brick acid, etc. I assume once something has etched the surface the roughness creates nucleation sites and cavitation bubbles start drilling through the tank.
I hosed off the circuit board and left it to dry in the conservatory for a few months. I was thinking about lining the tank with epoxy but last night Robin Renzetti put a video on Instagram showing a repair of a vibratory tumbler with hot glue. I've already got hot glue so it's not gonna cost anything and should be easier to peel off when it doesn't work.
I didn't bother with a glue gun, just warmed the whole thing up with a hot air gun and melted glue sticks directly against the surface until I had a reasonably uniform coat across the whole bottom of the tank.
The finished product, as far as I can tell there's no holes in the glue but I didn't go up the sides and there are some pits still exposed, I should really coat the walls too.
I ran it for a while without fitting the circuit board in case it leaked straight away. I also put a piece of foil in to check it's still ultrasounding properly, I was a bit worried by making the tank heavier I'd mess up any impedance matching the transducers and tank may have, it seems to be fine though, that picture is after half an hour, I think the foil is suitably destroyed.
After a couple of hours, the surface of the glue is unchanged and it still seems well attached to the tank, aside from this small bubble in one corner. There appears to be water under it, I can move it around a little but I can't push it out, can't see how it got in either.
I'll update after it's had a bit of use in anger, or it fails, whichever come's first.
