Is that the stuff they line wagon trailer decks with? Have you a source of it at sensible money?Replaced the rotten plank,I’m sure why this one failed after only 14 years,is because I do a skid steer to enter the loft via a very low door,and the swarf on my soles gouges into the wood,opening it up to the weather .its keruing.View attachment 313827
Yes,ordered via my jewson account,it came on an International Timber lorry.Is that the stuff they line wagon trailer decks with? Have you a source of it at sensible money?
Water dripping down from the gutter line?Replaced the rotten plank,I’m sure why this one failed after only 14 years,is because I do a skid steer to enter the loft via a very low door,and the swarf on my soles gouges into the wood,opening it up to the weather .its keruing.View attachment 313827
Check to see if the removed plank was heart wood or off the outer edges of the tree where the grain might be more opened once the wood was seasoned. .Replaced the rotten plank,I’m sure why this one failed after only 14 years,is because I do a skid steer to enter the loft via a very low door,and the swarf on my soles gouges into the wood,opening it up to the weather .its keruing.View attachment 313827
Priceless...........I put them in the forge and gave it a talking to with a 4lb hammer......
shake n vac
Did you do it?
I've noticed in both Germany and Norway they have built in ladders on their roofs. Do you have that in Sweden? How do they attach? And both countries loved a glazed roof tile.Unloaded 8 pallets of roof tiles this morning in 1,5 hours. Enough to get the steam up
All laid out att end of day.
Roof about 50 years old and first one I see without rot so just tiles and sheet metal to replace.
View attachment 314346 View attachment 314347 View attachment 314348
did you use a clamp to weld itThose of a sensitive disposition look away NOW!
We barely have enough metalwork vices in the workshop at school and certainly don't have any BSW machine screws so when a jaw fell out of a Record #2 vice and we couldn't find the screws there was only one solution... it isn't as if we'll ever be replacing the jaws anyway.
Took it home and used some stainless filler to TIG it on for good...![]()
That's unusual ...here in the UK the membrane usually runs along the batons and is over lapped from the bottom up so any water ingress runs off . What's the reason for yours going gutter to apex ?Unloaded 8 pallets of roof tiles this morning in 1,5 hours. Enough to get the steam up
