Munkul
- Cumbria
Which laser cutters do you use?A pallet of laser cut steel from a local laser cutters, and a Dixon T3 holder from @James1979
View attachment 310886 View attachment 310887
Used Lakeland Laser this time. Best price I could find, and the lead time was 1 week. Quality is spot on.Which laser cutters do you use?
It will run in the workshop only when I'm in there. But thanks for the heads-up
They do put some heat out and you have to let it go through a cool down cycle before switching off. If you don't the controller fries...![]()
Beat me to itWatch out for the exhaust too, gets very, very hot, as you would expect.
It's like a "club tattoo" on the FB owners forum
Several of our May bushes have died this year, covered in sloes then died. Similarly across the road a May bush with a 5 inch thick trunk died this year. OddOur damsons have been hopeless this year and the sloes dont seem much better for some reason
Is that battery big enough? The CDH take quite a few amps when starting up, low power is one of the common reasons for not starting.One of those diesel heaters that YouTube was full of a few months ago.
Not exactly acquired, but rediscovered after (many many) years buried in a box of bits in the shed.
Can't for the life of me remember what car it came off ... I want to say a Renault of some kind maybe???
All I know is I thought it looked ace on the bonnet of my Mini Clubman when I was 18![]()
Nice find. What is that signal strength meter on the display about?One of those diesel heaters that YouTube was full of a few months ago.
Quite a decent discount from new from a Dodgy geezer flogging Amazon returns at a guess.
There was diesel in the tank and the wires had been connected. He knocked another fiver whilst I ummed and ahhed....
So wasn't too surprised to see this.
Common fault jammed fan. Some percussive maintenance required to move it on the shaft.
Rubbing on controller.
Fan is free to spin an it works
Now upgrading with a fuel filter and isolator switch. On its own little trolley.
It will have some kind of power supply too,Is that battery big enough? The CDH take quite a few amps when starting up, low power is one of the common reasons for not starting.
You can run some of them off your phone on Bluetooth. Remote start etc. I’m no expert but a lot of the info I read appears to suggest they are all the same but some have more features unlocked than others. I’ve never gotten into it but I assume the unlocking is reasonably easy.Not sure, I have a remote control for it so maybe it is to do with pairing the remote?
Either that or the Chinese are hacking my WiFi....![]()
