Seadog
Save the planet. It's the only one with rum!
- NE London - UK
Some people should stay far away from electrics.
Some people should stay far away from air
They confuse it works with its safe…. That’s the problem with electrics vs plumbing in that you will find out fairly quickly if something is not plumbed right vs electrics that can sit happy until a fault/the right conditions occur and bang…This is the problem! DIY Donk thinks he knows it all and as it's worked fine for years it must be OK.
I did that in the last house. Worked well. If you’re of a certain mind you’ll probably do it neater and more carefully than a pro who wants to get to the next job. But. I took guidance from him every step and left everything open so he could see it beforeI wired my entire house, ground up, on my own.
With All the tails left un terminated at the consumer unit I called a spark in to connect whilst all the walls and ceilings where still down.
He couldn’t find anything to pull me up on.. he then wiredthe consumer unit (which I was happy to do myself but knew he’d do it neater) up and signed it off.
You don’t have to be qualified to be competent.
Fixed it.
I served a full apprenticeship, 4 years, why do folks think that they can learn everything in 10 minutes from YT.....
.....You don’t have to be qualified to be competent.
I just tell the customer they need to get a sparks in.Same for these cowboy fitters who'll fit kitchens, bathrooms etc, instead of hiring in the right guys to do the job properly, they'll do it themselves to save a few quid. if it's a wee move a socket here and there aye maybe, change a light fitting etc but when it comes down to knowing the regs etc, most won't have done it, or couldn't do it if they tried.
I served a full apprenticeship, 4 years, why do folks think that they can learn the same trade in 10 minutes from YT.....
wasn't a pop at you, seen the photos you've put up of your jobs, couldn't see a stetson anywhere........ ahhaahahhahI just tell the customer they need to get a sparks in.
My sparks is in Wednesday for a kitchen 1st fix
Il change a light fitting/socket or wire in a cooker like for like but that's my limit at work. (home.i have a bit more leeway)
Gas Safe in Monday to disconnect and make safe and will be back end of job
Doesn't save me anything doing it myself
I know my limits. I've said to customers in the past that jobs are either beyond my skillset or I don't have the means to undertake by myself.wasn't a pop at you, seen the photos you've put up of your jobs, couldn't see a stetson anywhere........ ahhaahahhah
Found out later he had rewired his house himself, earth carried current.
Did the same . . . wondered why the cooker hood didn't work . . . he'd tightened one screw down super tight on fresh air in the fused switch - the conductor was floating free . . . the other one, the wire was in the right place . . . just not clamped . . .I wired my entire house, ground up, on my own.
Did something similar when I wired my 'new' garage several years ago. The spark's 'starter for 10' was for me to run the cables and do the conduit work and he would terminate and test. After a bit of a chat, and after he had taken a look at my other garage workshop (pre part P) wired by me. He let me do all the work and just did the testing. here's part of the install that he tested.I wired my entire house, ground up, on my own.
They confuse it works with its safe…. That’s the problem with electrics vs plumbing in that you will find out fairly quickly if something is not plumbed right vs electrics that can sit happy until a fault/the right conditions occur and bang…![]()
Brings to mind this old favourite, which probably applies as much to plumbing, electrics etc. as it does to vehicles (and I'm sure the rates have gone up!)the job im on at the mo is interesting to say the least. testing the wiring and found the 3d floor extension ringmain is fed of spur socket on the landingit gets better . took the floorboards up to disconect the spur socket and found it was conected to the shower cable with a jointbox along with another spur wired in 1.0mm cable to a jointbox then wired in 1.5mm flex to a socket
theres a list as long as my arm on the faults that have to be rectified
