MattF
- South Yorkshire
Made a bracket to hold a concaved mirror for my uncles drive because a kid tied a rope to it and his bike the cycled away ripping it down.. if he does it again i will post the CCTV
The damp was in the fire place which had been bricked up in the 60's using rubble and plaster they had bridged the damp course, so digging it all out and adding a few coats of tanking slurry then making access for it to breathe under the floor might help.Does covering it up actually cure it ! or did you carry out other works to solve the damp issue .
just asking![]()
That's so that the part can be trued up. If it was making two points of contact on each jaw you might struggle to bump the face into square. Always use copper sacrificial pieces on anything I don't want to mark.Shortened bolts, took some effort but they are 12.9's. Couldnt hold them in collets to turn due to length. Shortened the head and the grade turned very nice.
Fitted with temporary m8 studs.
What to chuck up...?
Feels 100x more secure than anything in the old chucks.
Odd thing is the stepped side of jaws are quite flat, seems to have a reasonable contact but usually they are radiused for two points of contact.
Any bits of it a bit thicker? Could do with a chunk 240x120x60mm 50 would do.I continued recycling the spark eroder I stripped recently. 32mm wall thickness Cast iron. The things you do when you have a forklift and a decent size bandsaw.![]()
Landed up with a nice L shaped lump to make a new jaw for the bandsaw vice.
View attachment 302872 View attachment 302873 View attachment 302874 View attachment 302875 View attachment 302876
Part of an espresso machine, don't know what its called but the old one was a bit corroded for my liking. It bolts to the grouphead and the shower screen screws onto it. The holes around the edge are for water to pass through, six is easier to mark out than four.
Better hope I can get it back together then, it's been in pieces nearly a year.I will approve anything coffee (as long as it isn't decaffeinated or instant) related as a matter of course!![]()
I see your starting on the trap door!For those that remember my gate build and asked “why are the gates so close to the garage, well I made space this weekend by removing the old garage. Need to do the fence to finish it off
Also finished the side door on my garage.
View attachment 301953 View attachment 301954
No cnc I’m afraid. For a hillbilly mate of mine. To go on his truck
