Onoff
- Sevenoaks, UK
Help it along with a nice big dollop of ice cream![]()
There was a fresh cream apple turnover pre the cake...
The planks were wedged in solid, one or two lines of holes wouldn't have been enough to get them out, I would have had to drill holes in the entire surface area of the two planks and I still would have had to use a chisel by hand.How about drilling holes through, across the width of the planks.
On your next fire place ???? Perhaps cut the wooden lintel in half minus a 4 inch wide chunk in the middle then screw it with a thickish bracing board to rejoin the correct length . Grease it with cooking oil etc . Pour the concrete using a mid board brace if you think you'll need one. Once it's been used and the concrete is cured unscrew the bracing board & gently ease / pull the greased planks out .The planks were wedged in solid, one or two lines of holes wouldn't have been enough to get them out, I would have had to drill holes in the entire surface area of the two planks and I still would have had to use a chisel by hand.
Funny you should mention that!I trust that's the pattern for all 4 sides?
That jig I'm using is the one I fabricated when I built my workshop as that has 9 sections that size (3.600 long x 2.100 high). I'm just repurposing it for the shed. It makes a convenient work bench!
The shed will only be 3.600 x 2.000.
You’re getting a bit good at them
