Barking Mat
Cuddler of hedgehogs.
- France, Brittany.
Rich coming from me, and my slow.... buys.I would be concluding the deal and handing over £100 quid, and arranging transportation.
How can you say no?
How can you say no?
A bigger lathe has been on the list for years and didnt really want a 'project' but I know it will sit there for 10 years and be scrap if I dont have itRich coming from me, and my slow.... buys.
Remember to let me know about that ColchesterA bigger lathe has been on the list for years and didnt really want a 'project' but I know it will sit there for 10 years and be scrap if I dont have it
Sods law 2 would come up at the same time a Colchester and this but this one will be a doddle to move its sat next to a forklift and my mate is fitting a 2 ton hiab to his trailer this week![]()
good idea ive used citric paste before works a treatGet it bought. £100 is a bargain. Gear easy enough to get made for not too much money. That gear only runs the power feed and screw cutting. Not the spindle.
I’d be half tempted to scrape the rust off as Pete said then make a citric acid paste, let that work in then hit it with brass wire brush and finally wire wool.
I mix it with wallpaper paste flakes just the right consistancy then keep moving it about on the surfaceI have tried all manner of paste mixtures with citric acid and the problem is mobility. Once the acid in contact with the surface is used up, that's it. Game over. With a liquid acid bath, the acid is more mobile and replenishes from the larger volume of solution.
That’s it just keep agitating with a brass wire brush.I mix it with wallpaper paste flakes just the right consistancy then keep moving it about on the surface
I have to say my experience with using a paste was more successful , I needed to derust my chevy pickups chassis after i stripped it down sandblasting would have pi$$ed of the nieghbours so i tried paste and found it got 90% of it back to good metal. Just lately ive been using phosphoric acid as it derusts and doesnt flash rust after youve cleaned it off. In fact if you dip it back in for a hour then let it air dry it leaves a protective coating and you can primer straight over itI went through a period of testing various mixes when I tried to make some home grown Nitromors. I had (have??) a ton of methyl cellulose left over plus some corn starch (from various sugru experiments).
I seem to recall I had some large, difficult to submerge parts I wanted to "dip". In both cases (Nitromors/citric paste) I discover the relative effects were hindered by the static goo not replenishing the active ingredient. I certainly wasn't about to agitate the dichloromethane mixture which was a fantastically dangerous substance (!) and I personally did not discover any significant advantages in using a citric paste for rust removal.
I concluded it was better to use a strong liquid solution and to keep brushing that on. Incidentally, I am not saying I am "right" or that anyone else is "wrong", those are just my observations from a number of tests I did which I am sharing here. It does make me wonder if agitating a paste to make it work is better than just agitating a liquid solution because the ideal scenario with citric is to allow it to work for several hours at a time!
I am also trying to second guess what might be the precise composition of Evaporust (a totally different type of rust removing agent) and if anyone has a recipe I'd be happy to hear it.
What makes you say it's totally different? The MSDS (Usually the go-to for this kind of thing) doesn't give anything away but it says the pH is slightly acidic (6.1, about the same as dilute citric I'd imagine) and a quick Google says its Tannic acid.I am also trying to second guess what might be the precise composition of Evaporust (a totally different type of rust removing agent) and if anyone has a recipe I'd be happy to hear it.
and twice as rustyI’m half thinking about this swift and it’s twice the price!View attachment 285700
The bird crap will be more tenacious than the rustand twice as rusty![]()
