I bought a big pot from the charity shop, and a 2KW ring off amazon for a tenner. Works great!
Don't leave the element in too long (see post above)!
Anything connected to home diy, like linseed oil, furniture wax , woos etc has gone up.Linseed oil, the boiled type is gone expensive. Little bottle of it in the local builders providers is over a tenner.
Not been mentioned but best to use a plastic container for the process. No point in using the cleaning power of the citric acid to clean a rusty bucket!
I filled an old deep fat fryer with a citric acid mix (not too strong) and used it to heat the mixture & the parts up to 70 deg c before leaving the parts in overnight to be cleaned.
It worked very well but the chip basket started to dissolve after a few days! It wasn't stainless steel but chrome plated mild steel! I left the mixture in the stainless steel tank for a month or 2, thinking it was safe - it dissolved the heating element in the bottom of the tank!
Lesson learned - only store it in a plastic container!
It will dissolve aluminum, copper, zinc, brass etc
Handy for cleaning up wood & also hot grinder particles that got blown onto a white works vanWill look that up cheers
thought I was far enough away & van is still perfect long after the incident.Handy for cleaning up wood & also hot grinder particles that got blown onto a white works vanthought I was far enough away & van is still perfect long after the incident.
That pic was post stir, I did wonder about the flakes sticking
Not if you leave it to long.Why is it the base ingredient for coffee machines then? Together with sodium percarbonate. It won't dissolve copper but will dissolve zinc leaving brass with a copper colour, which is easily removed.
