8ob
- Nescient in the vale
Ed, the lower section of the twist lock is for locating so the lower will come up through the chassis plate that should be the same shape as the lock and not round and into the frame on the picker plate which should also be the same shape, all the top part does is go up through the pickers chassis plate ,rotate 90 degrees and then clamp down using the adjuster.. All the locating is done through the lower section of the twistlock which is why it needs to be a snug fit through both upper and lower plates.
Bob
Bob
