zx9
- South East London
Ok, I try not to post on things that I am not sure of which is why I referred to BMS networks perhaps I should have Googled automotive CanDepends on if it's single wire, or twin wire CAN.
But I have seen twin wire where high and low don't mirror each other, and low is simply a lower voltage.
However, if it were BMS I would be removing nodes to see which one was bringing + or _ down, when both lines returned that would be the faulty node found, with all nodes out and still bus shorted to ground that would be cabling.I did not know that single wire can existed and by definition it would not be can as can needs both lines twisted together for spurious signal rejection same as Cat 5 / 6 etc. network or a balanced audio cable.
I now want to read up on can, not because I need to just because...
