What is a camel back and what is it used for?
Straight crazy levels used to transfer flatness from one item to anotherTo measure it things are straight, like a straight edge, I'm fairly sure.
How do you transfer flatness ?Straight crazy levels used to transfer flatness from one item to another
Just remembered about this post.Ok, I try not to post on things that I am not sure of which is why I referred to BMS networks perhaps I should have Googled automotive CanHowever, if it were BMS I would be removing nodes to see which one was bringing + or _ down, when both lines returned that would be the faulty node found, with all nodes out and still bus shorted to ground that would be cabling.
I did not know that single wire can existed and by definition it would not be can as can needs both lines twisted together for spurious signal rejection same as Cat 5 / 6 etc. network or a balanced audio cable.
I now want to read up on can, not because I need to just because...
A two channel PC scope will not cost a lot, for occasional on site use we had a Tenma USB scope which I think is just a generic Chinese scope sold by CPC / Farnell the same item could have come from any of the usual suspects with a different colour case and different name on it, just we had an account with them.
Plasma job?Yeah drew it up and cut out, got the folding done by a friend though.
Plasma job?
Looks great!
Nice job![]()
I've got a Hantek USB scope, two channels, was farily cheap and does the job for my little bit of tinkering from time to time.
Picoscope is the other name I know, but they cost much more and as nice as they are I couldn't justify the cost for my use.
It took three applications of resin before the chess table stopped drinking it. Rather than pour loads on which is a pain to sand, I left each coat for about 20 mins then used a plastic squeegee to remove the excess. I then sanded it back to through the grits from 60 to 400 and this is it with 2 coats of satin Osmo Polyx wax/oil.
It will have last light sand of 400 and one last coat. It has to be ready for my youngest daughters birthday on Thursday, it's a joint present to both my daughters.
I looked up board/piece sizes and there's a range of recommendations, so I went with standard US chess federation tournament sizes. That's 2.25 inch squares and 3.75 inch king height. The pieces are boxwood and sheesham, a type of indian rosewood.
There's quite a few things I would do differently, but as a first attempt I'm happy enough. I'll make the rest of the table later unless the girls like if as it is.
Cheers
Andy
