Thank you, I love learning.
And me.
Cutting compound ? Not oil, please explain.
God, I'm 45, and know nothing.......
I use something called CT90, for cutting threads and drilling. It helps a lot.
Personally I learned from trial and error, lots of the latter![]()
and the glass of wine
"I love the smell of Rocol in the morning, it smells of victory."And me.
Like it.Its alive
are you anything to do with this guy?Few more arty bits
I use cutting oil I picked up from work work years ago (Cooks) - also trefolex is good for tapping and hole saws
wd40 squirty cutting fluid in an aerosol from Screwfix is handy for site work as it’s convenient and doesn’t spill everywhere!!![]()
Dymo tape, proper old skoolStill recovering from an operation so benchwork only at the mo'.
Using my Makita die grinder with Roloc discs always ends up mullering them as the die grinder runs at 25,000 revs. Rolocs are fine on air die grinder at around 10,000 revs, so slowing the die grinder to something around 10-15,000 revs should do the job. So with this in mind, I bought this cheapanese PWM controller and built it into a plastic box that I had kicking around.
This is the finished item. Description says that it handles 2000W. With my experience of Cheapanese electronics, I thought it quite likely that the magic smoke will escape at that load so won't use it on anything near that. The die grinder is only 400W, so hopefully the controller will live.
The ultra short lead is so that the box will dangle just below the workshop power points, which are quite high on the wall, so I'm hoping that the box and the delicate potentiometer knob will be clear of workshop rough and tumble. On a quick test with the die grinder it seems to do the job OK.
Cheers mate. Just got back in and seen it.@ukracer, pm sent
