Parm
Respect The Sound System
- Towcester
I cant tell from the info provided. Still, worth doing properlyI assume it's in his garden, and he's not starting a boat yard?
Really?
Really?
Really?
Having worked in a boat yard for many years I have lifted quite a few boats.But you dont know the whole reason why i want to do it. aswell as a project its more than that kida. If you want to safely and quickly lift a boat this is easier and quicker or boat yards would just use blocks etc
If you do not want cross beams, to stop the two uprights meeting each other under load, do you have enough room for guy lines even if installed only when lifting?
If it is only for this specific boat, concrete in a steel socket a lot closer to the hull and only install the uprights when you want to lift something. That way, the uprights do not need to cope with as much bending stress caused by the 1m overhang.
One winch each end with a couple of jockey pulleys is cheaper than two winches each end and means you only have to control two items, not four, to ensure it lifts level.
some with travel hoists, some with forklifts but many many more with Jack’s and blocks.
You can easily get the boat off the trailer and then raise or lower it very simply, even slide the trailer in and out without the additional costs of a hoist.![]()
What you really need is 4 x 10 ton (for example), bottle jacks attached to the trailer.
As high lift jacks as you can find.
Reverse boat into winter position.
Jack it up.
Block the keel,
Support rear end either side with supports, like big axle stands.
All the weight is on the keel, the side supports are just to stop it falling over, obviously.
Pull out trailer, side supports on the front.
I do this alot...
Although an overhead gantry crane / frame is a cracking idea.
Don't reinvent the wheel, copy existent ideas...
Really can't comment on the depth of foundations, depends on how solid your ground is I guess?I have one and sods law it a wee bit to narrow lol, i was going to make another to match.
I thought it wasnt a new idea, only difference i can see is it fixed and not mobile. So my only concern was how deep for the foundations for the uprights. Which yet nobody has said how big they need to be.
that depends on if your in to solid clay for how far down. you could weld some t pieces on the bottom to stop any rotation of the poles pulling in and widen the trenchI have one and sods law it a wee bit to narrow lol, i was going to make another to match.
Ok idea, use removeable top cross members, reason i dont want the uprights so high is it is forward of the house front line.
So what size cross member ?
a scaffie pole
I wish...Is that your boat lift Mat?
when can I have a play?
