NiceMade a pair of triangles the other day, and cut and welded them together last night.
View attachment 256107 View attachment 256108
One more pair to do.
For a very chunky dining table!
 What size box section is that? Just wondered as someone has asked me if I would replace the legs on a heavy oak table with steel ones
75 x 3mm square. It's a nice compromise between 50mm and 100mmNiceWhat size box section is that? Just wondered as someone has asked me if I would replace the legs on a heavy oak table with steel ones
Thanks, and I agree75 x 3mm square. It's a nice compromise between 50mm and 100mm
Over the past few weeks I have been rationalising my 'small parts' storage - nuts, bolts washers, screws nails etc etc. Sizes range from very small nuts, washers, tacks etc to large nails, screws and so on.
I have four tower sets of eight plastic drawer towers each bought from Office world before their demise. This gave me 32 drawers (which could each house a ream of A4 paper), which clearly was not an economical use of 'segregated space"
After noting the internal dimensions of the drawers, I decided to create four basic box compartments in each drawer - and then make them either full height of half height. I used OpenScad for this since it is exceptionally quick and simple to produce all the box designs I wanted.
Then, various boxes were designed with varying numbers of internal compartments - to accommodate different sizes and quantities. I must now have around 20 different designs.
The STL file from OpenScad was sliced using the Prussa slicer.
The 3D printer was then put to work producing boxes. What a great way to use up spare filament!!! - I don't really mind what colour the boxes are.
So far I have printed about one hundred boxes - and I still have a some spare drawer spaces to fill.
Some drawers simply have four full height "one compartment" boxes, others have eight half height "multiple compartment" boxes - and others a combination.
Sticky labels on the drawer fronts will indicate what is stored inside.
If anybody wants the OpenScad code let me know.
View attachment 256119 View attachment 256120 View attachment 256121
Nice!
How long per box/batch?
A 'half-height one compartment" takes a little over an hour. A full -height six compartment takes about 3 hours.
I can wind the speed up a bit if necessary but I usually just leave it alone and look in occasionally.
I try to do the longer prints at night, and then slow the printing down by as much as 50% - so at least it is "doing something" instead of just sitting idle with the power on.
I can get approx 10 full height or 15 half-height boxes to a 1kg roll of filament.
The first box had 1.5mm walls but that was too thick and took too long to print.
Next one was 1mm thick base and walls - very quick but a little flimsy.
Finally settled on 1.30mm for base and 1.25mm for the walls.
Malc
I bought a sheet of foamex sheet from the range, and glued it together with superglue, 20mm pvc angle to reinforce the corners...
But i like those boxes - its given me an idea for custom fitted tubs to go in my sortimo-style bits cases...
If you want to speed it up, use a 0.6 nozzle. Less travelling per wall thickness and less layers for a given height, quality is a slightly lower but I think the lower print times far outweighs that.
Good call. I may try that later. It sounds interesting. Thanks for the suggestion.
At present the base layer is 0.4mm - max for the nozzle, and the rest of the printing is done at 0.3mm layers.
I could go and tweak Mr Prussa's print settings - I've noticed that the edges of the walls are printed far more slowly than the middle layers for example.
I was using the Repetier slicer, but I noticed that the Prussa slicer was available in the Ubuntu store so downloaded and tried it. I found it MUCH better, with far more options.
Malc
I think i burnt out my CB power supply.
Trying to get a deep etch so i can pour a thin layer of coloured epoxy to simulate enamel, but it cut out after 30 minutes (i figured 60-90 minutes to get a 0.5mm deep etch)
I also experimented with thin lines to see how thin i could go before i get undercut.
I bought myself a volcano(?) nozzle, and 3mm(?) filament for my anet A8(a6?)
That looks interesting. What is the material you are using?
Malc.
Zintec offcuts from the big sheet i bought to line my trailer.
1.2mm, i think.
Etched in a saturated table salt solution.
Positive to the plate.
Negative to the "sacrificial" piece of mild steel.
(I say "sacrificial", - it is effectively being electrolytically de-rusted, but at too harsh a current for normal de-rusting.).
Is the use of ferric chloride workable? or is it too harsh?
I used to use that years ago in order to produce printed circuits for electronic projects - although electrolysis was not needed with the copper - it was just a passive reaction.
Malc.
