DAPPH
as dyslexik as I'm daft
Bright steel round nails are handy bar lengths in small diametersAn example.
The rivets here have long gone.
The holes are not the same size. But a 4mm drill had that soon sorted.
New rivets, made from round bar.
if you counter drill the end of a range of slightly bigger bars after grinding the drill bit to a half round with clearances you can make a range of " rivet snaps "
Heat the end of the nail whilst it's securely held in a vice to cherry red and form one dome head on it using the snap if you slightly undersize ( 1/64 th ) predrill through the collar / sheath of the tool and the wooden shaft you can usually tap a red hot domed rivet in and still have enough time to form the other dome head whilst there is still a fair bit of red heat in the rivert ....if you set the bottom snap securely in the vice before heating the rivet up .
Have one as the anvil and the other as the former to give you round headed rivets on both side
If you have any casehardening powder .. case harden a set from 1/8 th t0 1/4 of an inch going up in 1/16ths
