The_Yellow_Ardvark
https://www.death-clock.org/
- Going Away.
Not me.
But a "Expert" at MIS.
This guy thinks he knows it all, but 99.99% of the time it is BS and taken from the WWW.
This is a classic example.
This was set up at my place to show what was wrong.
Paraffin Blow lamps are very common, 60% are not worth repairing but look good to look at. The other 40% are worth spending time and funds to get them going. Service parts are cheep.
I always replace all seals, they are in the kit.
This person only replaced the cup washer in the pump and "Declared it was now fit for use."
First use, he primed it, pumped it up and after it was burning nicely the Pump to tank washer failed. Allowing paraffin vapour to escape with the resulting fire.
I now have to get a new CO2 extinguisher, as it was sued to make the torch safe in MIS.
When it all had calmed down and new coffee made, our expert was heard to say.
It had to be cheep parts from china, he could not made that mistake.
A rectum on legs.
Just had an interesting coffee break, with the MIS chairperson and the Membership register person.
I have pointed out that I had to replace the used CO2, at the cost to the MIS.
I explained to them why it had to be replaced.
Unlike one member who insisted it would be ok to use.
Plus no "hot works request had been made, so the blow torch should not of been in use.
This means the member has broken our H&S rules, to the cost of the MIS and the session leader was not enforcing the rules.
Both breaches of the membership T&C.
With luck some action will be taken.
