eLuSiVeMiTe
That didn't give up easily. Any screws into the oak legs snapped
Trusty crowbar to the rescue
Fme - you've managed to clear out enough space for SWMBO to park the horse lorry somewhere else!Finished the cutnshut and shortening of the boat trailer today, fits the urban artic a treat and its a lot more manoeuvrable. Just the landing legs to fit now and then on to boards, airpipes, wires, brakes and paint.
View attachment 241078 View attachment 241079
View attachment 241080 View attachment 241082
I am only 6 ft but find most benches too low to work on. It took me ages to work out how high to make the lathe bench and when I had finished it looked way too high but in use it is perfect.
next diy project. electrolysis....
bit of a practice run with the sub frames off of a scrap car. they're very corroded, and are going in the bin most likely, but make ideal large scale test subjects for the new 'rig'
kit needed:
1 ibc cut at the 150l mark
1 inverter dc tig/mma/plasma cutter.
4x bits of scaffold pole as the sacrificial anode
some wood
a bag of soda crystals.
some wire.
and you end up with
and a quick walkaround
the next version i'll make a wooden support all the way round the outside to stop it flexing, and so i can take the cross member off the top without draining the tank.
its bubbling away nicely at 20amps. might turn it down a bit more, there's a balance between effective and just wasting electricity heating the water...
also please ignore the bodge that is the earth wire going in the side of the welder, I've misplaced the earth wire and the dinse connector on my other tig is too big.
Made a mess of my first resin hybrid bowl
I bet it let out a bang that happened, what was wrong, did the tool dig in or was it just thinned out too much?A little bit of both. I used a skew chisel incorrectly and dug in. The mortice was too shallow and yes, it went with a bang!I bet it let out a bang that happened, what was wrong, did the tool dig in or was it just thinned out too much?
a couple of hours in....
) very tiring ....
yeah a ibc frame is ideal to stop floppyness![]()
Did you mean to tag mefit a good hose on the end and you can fill up 25 litre containers rather well from there taps
wash out the last junk in another 25 litre container and its clean put the rest back in container when needed
better if it was a little higher up as well so could poor into it
best way make a steel frame sit it on it then make a walk way at side of it or front of it when clean out time open tap fill your containers
@KimB
. My parents just bought this 1948 Fergy so I went through it and then finally got it run. I stripped tank and rocker cover to lube it all to avoid the old dry start. Then drained tank. Cleaned carb and lines etc. Found an issue with the stopcock so hopefully we can fix it properly tomorrow and then I’m going to hopefully be converting to 12v.
I'd go with the conversion to 12V and from dianamo to alternatorI’m going to hopefully be converting to 12v.
Starter motor has some internal damage somehow when I stripped and cleaned the contacts so it just makes sense rather than buy a 6v starter and battery. May as well just get the 12v of each and a new dynamo.
