zx9
- South East London
Nice tip @Hopefuldave I will be using the tailstock for a bit more rigidity next time I am torturing the Drummond.Until you add support on the vertical... Bring the tailstock up and lock it against the back of the milling slide for the cut, helps add a bit of rigidity and you'll get a more consistent milling cut with a better finish - I used to do that (had topslide on a big angle plate bolted to the cross-slide tee slots) before I got my milling machine, it made milling on the lathe a bit less unpleasant!
Dave H. (the other one)
