Riccardomuscarella
New Member
- Italia
Goodmorning everyone. I'm the guy in the video. it's the first time I've used a plasma cutting machine
in Italian but subtitles are available![]()
Suspect that's so they can put it on a UK 13A plug without soldering a piece of 1.5mm copper down the back of the fuseI can't see any jumpering, plug or otherwise. I suspect that the two pots on the top circuit board set minimum and maximum current.
The board is marked ECOCUT40EU003
Edit, edit:
which ties in with this product which clearly is identical.
, and had a go.
Plenty on eBay & seem pretty cheap!So next question is...what consumables do we order?
Is some lucky person going to get that for Valentine's Day tomorrow?
Which ones though?Plenty on eBay & seem pretty cheap!
Saw these ones:Which ones though?
( Haven't go my hands on it stuck at work)
Saw these ones:
https://www.ebay.co.uk/itm/352961051289
Seems there are a number of different length consumables for the pt-31 torch. Going off the main electrode (long, thin on both ends), the Lidl unit uses 38mm part but some are 28mm and some are shorter. I guess if you replace all the bits with a matching set you should be ok.
Anyone else know for sure?
He did well, got everything on my shopping list
That's going to cost you in terms of beer and pizza.![]()
