heldtogetherwithblutack
- Newton Solney
https://www.lidl.co.uk/en/p/diy/parkside-plasma-cutter/p29579
30 Amp version £79.99
- Durable, powerful and compact
- Electronically controlled, quiet and even plasma jet
- For precise and clean cuts through material up to 9mm thick
- Suitable for cutting sheet steel, stainless steel, aluminium, copper and iron
- Adjustable cutting current: 15 to 30A
- High-quality 2.5m cutting cable with replaceable burner attachments and detachable roller guide
- 2m earthing cable with strong clamp
- 2m compressed air hose with quick connection system
- Compatible with standard compressors
- Must be used with a compressor – not included
- Rear compressed air connection including pressure reducer
- Overload protection due to the thermal monitor with indicator light
- Housing made from painted sheet steel with an ergonomic carrying handle
- Includes 3 burner covers (1 pre-assembled), 3 electrodes (1 pre-assembled), roller guide and compressed air hose with quick connect system
- Cutting current: 15–30A
- Cutting performance: copper: 1–2.5mm ; stainless steel: 1–6mm; aluminium: 1–6mm ; iron: 1–8mm; sheet steel: 1–9mm
- Working pressure: 4–4.5 bar
- Rated voltage: 230V / 50Hz
- Cable length: 2m
- 3-year warranty
