jordhandson
- Dorset
Cheers Barkin, Father also says I am improving, which isn't difficult when you've got a mill and a lathe, and all youve be use to is the angle grinder and the welderLoving the precision of this build, lovely work.
Useful video, Tony Foale's Thread was brill thanks Dave![]()
its appears alot better of a build than what you was planning to build in the first place
its been an interesting watch of the build and nice to add some input into the build of it
@jordhandson Reading your progress and the good work your doing, I feel very guilty knowing I have a Quorn machine presently sitting in three boxes, two of which I haven't even opened......And I only opened the one containing the motor [among other bits] to make sure it worked.
So many projects means that it'll be some time before I unpack it all. I don't want bits of it scattered around and neglected while I have to attend to something else.![]()
you have no excuse not to build it up and sort some stuff out when you can a good chunk of it was already prebuilt up for you
I have picked up a inclinometer I thought it will be handy for setting angles, it was only a couple of quid.
I saw them at the same place I have a digital one on the way as well. I thought they looked interesting. and cheap as chips I gather because there in inches measuring and not metric.i picked up one last year thought the same as you as i kept seeing them in use on youtube videos
but not all levels are true not even the building levels are
there nere but not exactly level even an engineering level is not a true level
Gaz, the digital angle gauge arrived today its a clever little gadget, you zero it on something you know is level then it changes as the angle changes, its got a good size readout as well
i got one these too .i like it but don't know how good it really is. probably cost more to get it calibrated than it cost to buy
