eLuSiVeMiTe
Had to block himThe last time i worked as a naturist it was a bitter winter and the customers complained about my shortcomings![]()
Recon it was a windup but was a genuine account..
Be interesting to compare them when they have had a bit of use.Courtesy of that damned farmer's co-op tool store.
A brace of aviation snips. One LH cut from CK, and a straight cut from Dargan (local tool importer from cheapaneseland, but ususally ok).
You'd think they came out the same factory...
PhotosToday, my order from Zoro arrived - keyless chuck (seems a robust bit of kit), along with a rubber hammer and carbide turning insert to make up the order to "free p & p....![]()
!6 bags of coal and a tin coal bunker. I still might starve to death but at least I wont freeze!Coal bunker is almost the perfect size for keeping the Rapidor in..
Ten minutes after the last of the emergency discs went in the grinder.But have your discs arrived yet?![]()
Ten minutes after the last of the emergency discs went in the grinder.![]()
YOU still have not returned my Red mug.
I love those drill chucks
Buy another arbour to suit?Well I got my order through today, 2 screwdrivers, a sds adapter and the chuck. The chuck really is a nice heavy piece of kit, unfortunately it's not going h to fit what I bought it for!
Who would have thought that JT stands for Jacob's taper?
I wanted it to fit on my Bosch SDS drill as the old one is a bit knackered.
Oh well it's a nice chuck.....View attachment 206939
if you have a lathe use it on that . with a jt6 - to 2mt arbourWell I got my order through today, 2 screwdrivers, a sds adapter and the chuck. The chuck really is a nice heavy piece of kit, unfortunately it's not going h to fit what I bought it for!
You can do many things with itAnother load of 50mm thick foam off cuts , not foil backed but still better than nothing.
