123hotchef
- Kent
A few hairy moments but hey it is nearly ready to be cleaned up and put to use
ill take a closer look inside i didnt see any feet it sits on the cabinetDon’t bolt it, it should have levelling feet
Nice idea it may be a bit low actually but it might wobble if I make it a foot higher on feet lolThat is correct. However, you may find it's a bit low so worthwhile buying or making some levelling feet.
I will have another fiddle tomorrow i removed the 2 screws near the chuck but it didnt budgeYes, it engages the back gear. They're sometimes locked off with a machine screw if it came from a school.
I think if a machine I was looking at had been used on wood, I wouldn't buy it. Purely due to the amount of work that using a metal lathe on wood generates. It's bad enough if they've been used with metal and neglected.
You will soon learn this eternal truth:-
Lathe = machine for making milling machine parts.
Milling machine = machine for making lathe parts.
It looks great what you have bought. You'll find lots of help here.
Don’t bolt it, it should have leveling feet
Oh and is this lever suppose to move
Yes it is; it's the backgear change lever. The idea of the screws is that one of them passes through the headstock casting, locking the lever in place and actuating a microswitch inside; unscrewing it then drops out the main motor contactor as a safety feature so little Johnny can't crash the spindle gears with it running. It should still work as long as the interlocks haven't been bypassed.
Undo the screws, press down on the knob and the lever should tilt and then turn through a short arc (20 degrees or so) which slides the backgear in or out. Help it along by turning the chuck by hand, you'll soon get the feel for it as the lever won't drop into place if the teeth don't mesh properly. Retighten the screws (usually only needs one of them doing up for each position) until you hear the microswitch click and you're away.
Do not forget to oil the backgear: look through the hole in the front of the headstock and rotate the spindle by hand and you'll see a ball oiler appear. Apply oil can and squirt awayThis is probably the most-neglected maintenance task on a Boxford (I'm on my second, the first being an AUD and the current a VSL500).
Ian
