Seadog
Save the planet. It's the only one with rum!
- NE London - UK
Why would it be, Pete?
If it wasn't then the keyway it located with on the shaft would also be cut at an angle, constraining the flange to only one position on the shaft with no facility for axial adjustment.
No. Yes. Don't know. Hahaha. It's a parallel 5mm square key that is cut parallel to the taper. The depth of the key way is the same either end of the taper. So it's not cut parallel to the centreline of the shaft. If that makes sense ? It's off the fan drives on the big V12 Maybach engine in a Panther tank. I copied a very rotten original.Nice. I take it the key is also tapered?
Goes on here. One each side of the engineView attachment 172158
Ze Chermans ja...Cool. Odd way of over-complicating a key but cool nonetheless.
Not today but yesterday. A new hydraulic cylinder for a 7t caterpillar excavator. The only bits re used from the original are the two eyes
Cat still using JIC fittings or have they gone onto something more available?
A pal had a Cat for a time and hoses for it were flippin' eyewatering...
Nice chisel. A dovetail one if I'm not mistaken.
