The_Yellow_Ardvark
https://www.death-clock.org/
 - Going Away.
Nice chisel. A dovetail one if I'm not mistaken.
A 3/8th Bevel Edge chisel. Has taken a decent edge as well.
I think a soot lamp is more traditional. Plus more fun.
.  The plan is to clean the joint and then solder it.  The eagle-eyed among us will note that the lid knob isn't the original, it cracked and had to be replaced
.  Also, the small nut inside which secures the forward end of the handle is slightly slack.  I can't get a spanner or fine-nosed pliers in so my only hope is if I find one in the box of spanners I collected at my brothers, having bought them on Facebook marketplace from a guy in Livingston, or if I have a socket small enough in my set [or if my neighbour has one].
 . It needs cleaning with bleach - that's what happens if you drink exclusively black coffee
View attachment 172122 Made a couple of flanges with a tapered bore and a 5mm key way cut parallel to the taper. All good fun....
Why would it be, Pete?
If it wasn't then the keyway it located with on the shaft would also be cut at an angle, constraining the flange to only one position on the shaft with no facility for axial adjustment.
Goes on here. One each side of the engineView attachment 172158
Not today but yesterday. A new hydraulic cylinder for a 7t caterpillar excavator. The only bits re used from the original are the two eyes
Cat still using JIC fittings or have they gone onto something more available?
A pal had a Cat for a time and hoses for it were flippin' eyewatering...
