Kayos
Gone......
- North Lincolnshire
Prices seem to go up in winter
Back in the summer you could pick up a Rover 75 or D3 unit to warm your coolant for about £70
Now you are just rubbing it in
Always the way with anything seasonal related I findPrices seem to go up in winter
The chinese stuff is cloned in appearance however the materials used are not the same , horses for courses , but yet to see a European OEM use a chinese heater, the testing and validation before release to vehicle production takes considerable time and money, remember there are still plenty of Eberspacher D1L running and those are 20 years old minimum, wonder how many chinese heaters will be?
I'm firmly in the "tight bunch" but personally I'd spent the extra and get a Webasto or Eberspacher. Whilst they are a fairly simple bit of kit for peace of mind if nothing else I'd only be happy with a properly engineered heater and not some Chinese knockoff.We're generally a tight bunch on here, So might struggle to convince us to pay more!![]()
@Kayos there were Webasto heaters fitted to other Land Rovers and also some of the Rover cars. Have 1 in my D3 and think it's about 5Kw, no remote and it kicks in when temp drops below 5c but I have acquired a GSM remote for it so I can get it warn and toastie by sending it a text.
The D3 uses W bus protocol but you can buy a gizmo off eBay to activate it via a switch if retro fitting
It's not a warn air heater but warns the engine coolant and circulates it
I would buy secondhand if I wanted a branded productI'm firmly in the "tight bunch" but personally I'd spent the extra and get a Webasto or Eberspacher. Whilst they are a fairly simple bit of kit for peace of mind if nothing else I'd only be happy with a properly engineered heater and not some Chinese knockoff.
worked strait off only issue is it only has 3 settings full power till 90C, 1/2 power to 80C then off. (might be full power to 80c then half to 90 then off can't remember )I'm with Wookie on this, no way would I trust to sleep in the camper or just leave the Chinese heater running without being there with it , Ebers I trust 100% and happy to sleep with it running.
Edit to add
Bought a as new D5s water heater from a newish RangRover (30quid ebay special) bought for the silencer on it, worked out the wiring, made a harness to try and see if I could get it to do anything as it looked so new....worked strait off only issue is it only has 3 settings full power till 90C, 1/2 power to 80C then off. (might be full power to 80c then half to 90 then off can't remember )
Try thisDo you have a link to the switch? D3 webasto's sell for nothing on ebay. Bought one for £20
I've got a Webasto in my camper, over 12 years old with no problems, a friend had a van conversion done & they fitted a Chinese copy. It ran for about 4 hours total & went wrong, when it went back to the importers, it turned out the fans were made of plastic & had all melted.
Also check out ford galaxys,few of those are fitted with a webastos@vwmark
Do the Ebay search as "Range Rover water heater" you will have loads of eber/weba results to look through, mostly from breakers.![]()
That doesn't bode well for the Chinese copy, even if it had been fitted badly it shouldn't have melted itself.I've got a Webasto in my camper, over 12 years old with no problems, a friend had a van conversion done & they fitted a Chinese copy. It ran for about 4 hours total & went wrong, when it went back to the importers, it turned out the fans were made of plastic & had all melted.
Okay so they both use a plastic moulding for the fan blades, but is the plastic suitable in the Chinese copy ? Does the Chinese copy have overheat protections etc etc just because it looks visually similar doesn't mean it's built to the same standards.Just watched a youtube video of someone mending an Eberspacher - it also has a plastic fan - as it is on the cold air side shouldn't matter.
Now the Chinese copy could be brilliantly engineered and solidly built or it could be made of cheap components that aren't up to the job.
I would hope the Chinese copy blows cool air over the heat exchanger the same as Webasto & Eberspacher's do rather than being mounted on the hot end but who knows, I haven't seen one.
Personally I'd just get hold of a second hand Webasto or Eberspacher unit rather than take a chance on the Chinese copy.
