Jlg
- Cumbria
Do they have a bit on the other side to do thatCan you take the opposite jaw out of your chuck and perhaps turn the screw from the other side to the broken bit
They don't look like bad value but they are out of stockBought a nice set of glanze indexible tooling designed to use one insert for all. Well worthwhile. https://www.chronos.ltd.uk/acatalog/info_777102_.html
Various sizes available
Aye but available in other sizes. Not sure what you would need for yours. Managed to squeeze 12mm in mine.They don't look like bad value but they are out of stock
Great - Thanks for the help. better get my (narrow) spade out!
Give em a call for an eta if 8mm is required. Just down the road from me so picked mine up in person.
Wife doesn't know how much they cost...
They are. Was looking at there indexible milling tools tooThat got me lookingIncredible value for money
https://www.glanze.co.uk/acatalog/Boxed_Sets_of_Lathe_Turning_Tools.html
Bob
That link has the size I need in stock might just order of them not much more than banggood but delivery will be quickerThat got me lookingIncredible value for money
Bob
Double check what size you need.That link has the size I need in stock might just order of them not much more than banggood but delivery will be quicker
I've got 12mm tools at the minute and there just a little too high so I would get the 8mm tools and I can just shim them up until I get my quick change tool postDouble check what size you need.
I ended up facing off the bottom of my tool holders by 3mm to get tools on center
They do them at ten mm tooI've got 12mm tools at the minute and there just a little too high so I would get the 8mm tools and I can just shim them up until I get my quick change tool post
10mm was almost spot on with my four way tool post. Like I said earlier you won't get the boring bar on centre with the four way, it will not go high enough.They do them at ten mm too
Could you not machine a spacer to go under the tool post.10mm was almost spot on with my four way tool post. Like I said earlier you won't get the boring bar on centre with the four way, it will not go high enough.
That would work, a Dickson tool post was the option I went with.Could you not machine a spacer to go under the tool post.
Are they quick changeThat would work, a Dickson tool post was the option I went with.
Yes. One is on my list.That would work, a Dickson tool post was the option I went with.
Yes.Are they quick change
Where can you buy the leather drive belts that hook together
Yes.
