gavuk
artful-bodger
- Wilts
Just stripped down my lads moped ,1998 rs 50,need to order some replacement bearings,on splitting the crank case i was suprised there was no gasket,any recommendation on re-assembly use a sealant or not?.......also the seals, nitrile or viton,looks like ebayer's are supplying nitrile as viton is x7 as expensive,and lastly the bearings normally use skf or fag at work ,ebay sellers are offering koyo like the are better any views?and lastly etn9 low friction fibreglass cages would thes be worth any extra expense,will they last as long?......i will be checking numbers as i strip them out just wondering if there are superior parts that can or should be fitted to try and keep the bike reliable for another 12months........cheers Gav
ps just noticed the mains are c3 clearance and skf
......i'm still pulling bearing bearings out today ,and am wondering which replacements to order koyo,skf,fag?any views welcome..........Gav.......
.......thanks for the input Sam......got all but 2 out ,no rear access to them ,can't find my slide hammer
.....may have taken to work.....one a pressed steel needle race which being mounted in alluminium i'm not sure i fancy trying to fold it in on itself ,may end up using heat or tig to help,will attempt when i've warmed up tomorrow.......thanks again Gav
