You need Nitric Acid and Methanol.
Or stainless pickling paste. The nasty ones.
I've no had time to look in to alternatives...but what % Nitric Acid do you need?You need Nitric Acid and Methanol.
Hi Smashweld.I've no had time to look in to alternatives...but what % Nitric Acid do you need?
Would this do? https://apcpure.com/product/nitric_...wdKg3RH7TXni0FIBt1lnqp-S099LSeJRoC9-UQAvD_BwE
Cheers Brad....yeah sounds like a risk I should avoid. It’s just for testing my own work...prob a bit OTT but now I’ve read it I’m interested in doing it...
Possible daft question but will stainless pickling paste work with mild steel,macro etch test?
I just assumed pickling paste was something you made with the Nitric Acid when I read your first post but see now ithats not the case
Very neat. Got that dialed in i would say
Get a nice setting in the flat of 100-120A. Then do your vertical.Cheers, think in past I spent far to long fiddling with settings, with bit more time under the hood with mig, I seem to be able to get in ball park without thinking. Paying more attention to what happens in the weld pool than what's on the display.
got a new helmet at xmas...much better than old one! never realised you could see 'the pool' so well....old helmet was so blurry/dark in comparisonDon't move up as far when you are moving across the weld face, you are verging on getting lack of fusion between each pass
