123hotchef
- Kent
It is a new shaft that is made of Chromoly Steel and comes with oil impregnated bronze-nickel bushings.
A one off would be fine for me would it be chromolyI could do a one-off
But a few is a CNC job for sure
Would you turn the taper by using the top slide Pete or would you off set the tail stock?Getting that taper to finish in the right place would be pretty good fun.
I could make one but it would take a bit of time on my little 3hp lathe. Lot of material to turn off that largest diameter.
Other than the taper it doesn't look particularly challenging to make. Like you say most of the time involved in that is removing a lot of material from the stock.
The other minefield is, if it failed and an accident occurred the maker would/could be liable
That is a great idea too but the bit that pokes out with the threads and nut that hold the arm can still be bent easier being softer materialA better solution would be grind the journal's of the existing part and make new bearings
