No, I'm pretty sure what I ready, stated even on your own property! I think it was a new law they were bringing in to do with emissions, not the existing law of leaving car idling on public highway, I think that one is to do with you not being in control of your vehichle.yes in the street but it doesnt apply on your own propertyso the carbon emissions must be diffrent on your own property
I do wonder when I see empty vehicle sat running, often with the drivers door open, while the driver is "only away a minute" . . . I'm tempted to get in and move it down the road a bit . . . see what the reaction is. Or just take the key and walk off . . .
Perhaps that's a design feature so you can see when the breakdown trucks coming!Its not often I get to say this, my Landrover Defender has an excellent heated windscreen, demists quicker than any other car I have had.
put the water over then use the windscreen wipers and theres no water to freeze back up. de icers crap and leaves the screen all blurredSurely its not illegal to wait with a car with the engine idling if its idling to demist/deice the screens as its also illegal to use a vehicle that has iced/misted up screens causing poor visability?
Also those that use warm water to deice the screen how do you stop it icing up as you drive off? Everytime I've used warm water or deicer to clear the screen I end up having to stop 500 yards down the road to clean off the icey, sludgy mess that is now covering the screen. My way is to start the engine up and while its warming up and deicing the inside I'm outside giving the windows a scrape, always works for me.
We used one of those to keep the outside lavatory from freezing up, sadly the slight increase in temperature didn't reach the seat.old miners safety lamp
They do eventually crack. It may take years, or it may just take a tap with the palm of your hand, but they will eventually crack. It also depends on the windscreen, as some windscreens are quite highly stressed, so any weakness can very quickly result in a big crack.makes me laugh when i see the addy on tv. autoglass say leave the chip in your windscreen and it will crack . no it wont only if theres a slight run in it then it will travel![]()
makes me laugh
I make my own de IcerCBA waiting for cars to defrost.
Fill kettle from hot tap, just cool enough to put your hand in is about right.
Pour over windscreen.
Start it up and put wipers on intermittent, to clear the water off before it can freeze again.
Put kettle away, turn wipers off, go. The heat is just enough to clear any condensation from the inside, then the aircon stops any more from forming.
Works for me. All done in less than a minute. Every time I mention this I get dire warnings of how it'll crack the screen, break the bonding, etc. Not happened so far over 10+ years and four different cars. YMMV.
with that advice why do you need a screen heater?put the water over then use the windscreen wipers and theres no water to freeze back up. de icers crap and leaves the screen all blurred![]()
