123hotchef
- Kent
i need to try this are we saying slits or triangles?And don't forget they can be sharpened by putting slits in with a cutting disc in a grinder.
Pictures pleasei need to try this are we saying slits or triangles?
I've done loads, as have others on here!Unlikely to be cost effective or even possible at all. I imagine most of these disposable blades will be hardpoint.
www.toolden.co.uk
Must try that. It appeals to my inner Aberdonian.And don't forget they can be sharpened by putting slits in with a cutting disc in a grinder.
a good quality tool well worth having i. have the battery operated one which is a must for me using it a lot and not having to plug it in . need the quick change blade as wellI fairly shore this is the kit I have.
DeWalt DWE315KT Multi-Tool Quick Change Kit & TSTAK 300W 240V
Shop for DeWalt DWE315KT Multi-Tool Kit at Toolden. Free shipping for orders over £50. 0% interest-free finance available.www.toolden.co.uk
PhotosI've done loads, as have others on here!
its ok sharpening them with a slitting disk just cut thePhotos
Oh it doesn't matter. Just keep buying them!Photos
Same here, saw them and thought I didn't need one till I borrowed one for a job and was so impressed went and bought my ownMine very quickly became "how did I ever manage before!"
Chopping worktops neatly, skirtings, floorboards and even nice flooring that needed a notch
i already have some 2ah milwaukke batteries...was thinking mains might be better , cant see a 2amp battery cutting alot
Use the stainless tool to shave off as much of the sealant off the wall after the old bath is out as is possible , then use a sealant dissolver on cotton towelling to get the final bits off if it is on tiles . On bare plaster you should be OK just slicing it off flat to the wall & re-sealing round a full bath of water once it has stood & settled on the feet & flooring for a few hours . Do read the fitting instruction for putting in the new bath ..lots of folk don't and so come unstuck doing it.I’m about to change the bath at home & have been wondering whether a multi tool will cut the sealant between the bath & tiles, the sealant is CT1 so I don’t think silicone remover will work. Anyone tried?
Put " CT1 silicone sealant remover " into your search engine and have a good read . If you have a local to you Screwfix they might well have it on the shelves too for click and collect or an over the counter purchase.I’m about to change the bath at home & have been wondering whether a multi tool will cut the sealant between the bath & tiles, the sealant is CT1 so I don’t think silicone remover will work. Anyone tried?
I haven't had time to dissect it and see if it's fatal or if I can simply replace a part or two. If it's fixable, I'll post the repair on the 'Things you've fixed today' thread. This isn't necessarily a negative reflection on Bosch, as I've used (and probably abused) this tool quite heavily for years, so I'd still recommend both the Bosch and the DeWalt.
