some switchgear for my bike build...
View attachment 199838 View attachment 199839 View attachment 199840
Kram if you grind some HSS with a really steep top rake it will slice material off at 3x your current rate without stressing the motor.
Derlin/acetal. Nice machineable plastic.
Avoid nylon. It will do what you want but its like cutting dog ****.
Not that lucky. Most of the DeWalt gear is A direct fit thankfully. But need adapters for other tools to suit. Poly?Dont mind nylon with very sharp tooling, but when it goes wrong worse than dog ****
Id go poly myself if they are one size id cast them.
what size do you need..i have some nice chunks of machinable plastic here if you need anyNot that lucky. Most of the DeWalt gear is A direct fit thankfully. But need adapters for other tools to suit. Poly?
50 mm round bar should do the job at a guess matewhat size do you need..i have some nice chunks of machinable plastic here if you need any
i have square...must be about 100mmx80mm and whatever length you need. can send you some but it wont be till early next week as ime not going up to my unit till sunday morning50 mm round bar should do the job at a guess mate
Kind of what I'm doing now but when your mid cut/plane and it pops out all over a lounge it's a pitaPolyurethane as its flexible. But would be ****e the machine.
Thinking about it offer suggestions would be best just a little brittle
Would it be best to get a decent rubber coupler and adapt that then you can just wedge it in the orifices.
Will have a poke around on the bay first cheers. Round close to dims will save me a lot of time I don't have.i have square...must be about 100mmx80mm and whatever length you need. can send you some but it wont be till early next week as ime not going up to my unit till sunday morning
