madkayaker
Pro sparkey Pro Welder
might be a good idea to ask the environment agency being vague on location of course
If you dig a well will it interfere with your neighbour's supply? I've seen cowboy films where this happened and it started a range war![]()
SSI
do you know l sometimes have this nightmare that after spending 10 years biulding my little nature reserve, planting 4000 native trees at my expense one day some beared sandle wearing ex hippies turn up and turf me off my own land as l have great crested newts and other rare species
what a nightmare![]()
think l need to train the dogs to eat anything that moves or looks like a rare plant![]()
it was damp well more than damp wet infact
your digger not got lights on then?Well this thread seems to have run dry
but not for long, l had an exploratory dig tonight just to see what was down there, lots and lots of clay is the answer, went down about 12 feet or so and eurekait was damp well more than damp wet infact
trouble is the clay walls are not allowing the water to seep into the hole very fast,
the bottom of the hole is 5' wide 4' long and about 2' deep it took about an hour for it to fill with water, not fast enough l could empty that in 30 seconds with a pump, still it might get better further down bad light stopped play tonight
it happened to meyour digger not got lights on then?
was thinking of putting lots of slits in the sides and top with an angle grinder and then dig a hole and place it in so as the top is 6" below the water table, again have 6 to 12" of 20mm gravel all round it, then slope the banks back nice and shallow so as it dosent all slide in, weld a 2" pipe into the roof that extends down the floor inside the container and use this to connect a pump to, all l would have to do is look in the hole if there was water showing above the gravel on the container roof then l would know l could pump out 40 cubic meters of water, would have to start at 11 pm of course to stay under the 20,000 litre rule
You could also consider .. a 50 mtr long trench 8 foot deep .. pea grit on the bottom then two lengths of perforated 100 mm land drain or more say up to ten lengths or so of 50 mtrs ( 100 mtr rolls ) the sort that has the micro filter cloth on it .. recover in 10 mm clean stone for 30 mm or so then add 40 mm stone right up to the 5 foot depth bring them to a collector point / sump that has a concrete slab base add some 45 gallon barrels tack welded in line de topped and bottomed for the shaft .
Back fill round the barrels with a lean mix of concrete , cap off with 6 " reinforced top with a small child proof access lid.
That way you have a 50 mtr ( long or deep well / ) with the capacity of all the pipes ..seepage into the well should be better than most.![]()
Dowsing is weird - I tried it with a bent coat-hanger and definitely got some indications, unfortunately my parents wouldn't let me dig the lawn up to verify the accuracy of the indications!
Fred Dibnah lined a mineshaft with bricks from the top down, I can't remember the exact method but I thing he drove pegs into the side of the shaft to support some timberwork a few courses from the top, built the courses and after the mortar had set moved the staging down and built more courses upto the first lot. I think he left the pegs in place to support the bricks when the staging was moved down. Something like that anyway.
He also used a metal ring jacked up from the bottom of the hole while the mortar set. Fred did have the help of few friends who were ex coal miners and knew all about tunneling. Yet another skill lost to this country!
I'd say that you would have to drill that many holes at least 5 mm every 35 mm or so and in inch apart rows all round the pipe in diameter that you'd need to buy two quality hard working power drills to replace the current one you have in mind using ....
