Windy Miller
Semi-Professional Potterer!
- North Kent, UK
Fumes Fumes Fumes
Dangerous Fumes. Don’t forget about the DANGEROUS FUMES!!!
Weld close to the open door, and try to arrange stuff so your head is out of the path of the welding fumes, and get some sort of extraction too.
There has been a very informative thread about the health hazards associated with welding fumes - have a good read of that before you get stuck in!
, because I have CNC plasma and welding works as part of my workshop, the insurance royally bust ma balls for weeks because despite my workshop being seperated from the house, and being all metal cladding it does have a wooden framing. 150 x 150 solid timbers, their "expert" eventually accepted that a wood frame wouldn't be a problem for intermittent works, but insisted that I separated the "hotworks" from the rest. As a result, I now have a metal partition wall with fire retardent welding curtain strips as a divider, between the areas and additional fire extinguishers everywhere. Basically anything with sparks, or open flame is now all in one area... additional expense / works that I hadn't planned on when I set up the business.. Despite being extremely pee'd off about it at the time, after some time using it, I'm glad I did it in the end, frankly it makes it easier to work, so it's actually an advantage..
same with the grinder now I check 1st there's nothing near by flammable and go back an hour after finishing just to make sure
