roofman
Purveyor of fine English buckets and mops
- North West with water on 3 sides
How are you Mikey...love the bench btwDon't worry Brian I quite enjoyed your little rant , yea your right you do look like a tramp![]()
how many watts ? and where is the plug / cable stored cant see it
love this postI've modded mine (Hoover) 9kg made it hot fill and takes about twice the water does a full wash in about 45 mins now ,and now you can hear it washing you couldnt even see water in there before ! and everyone was getting skin problems rashes etc after my mods no problems.
we couldnt do with a wash taking 2 1/2 hrs sometimes we do four in a row
a propper washtrust you to mod a washing machineI've modded mine (Hoover) 9kg made it hot fill and takes about twice the water does a full wash in about 45 mins now ,and now you can hear it washing you couldnt even see water in there before ! and everyone was getting skin problems rashes etc after my mods no problems.
I bet you altered the screw on the pressure switch to get a higher fill, but how did you speed up the wash time ?I call it tuned
several screws actually it took quite a lot of setting if you go to much on one it then says the water valves are faulty. etc etcI bet you altered to screw on the pressure switch to get a higher fill,
By hot filling, I fitted a third valve (cut out was there and the pipe in the powder draw) and timer a momentary switch on the front panel so that when the cold valve opens it swaps it to the hot fill the timer self latches for predetermined time, the amount of water it now takes, would take at least 1/2 hr to heat alone I would say, on start up it says it should take 132 mins for the usual wash, we do in under 45mins it just takes loads of time off in chunks when it would normally be heating.but how did you speed up the wash time ?
WOW thats incredible --------------- but surely for it to reproduce--------- you must have bought two?? -----AH but it was a servis ---------so maybe could service it'self.14 years on, two kids later, two stone fatter and less hair- its still going strong
AH ha it was all in my master plan 25 yrs ago washer is on one side of wall from DHW boiler the other side, and no hot tap further than 12ft awaybut hot fill would be pointless for me as the boiler is at the other end of the house upstairs.
Yup used to use one at my Gran's as a nipper. Nowt as posh as that copper one though, more like the wooden one on the left here:OK who's used one of these???
I have -------felt a right posser
