Magic, that's steered me in the right direction, thanks!You need to sign up to Mitsibushi website but after that it's a free download
If you PM me your email I can prob send you it direct if you want?Magic, that's steered me in the right direction, thanks!
Thanks, I got it downloaded from the Mitsubishi site.If you PM me your email I can prob send you it direct if you want?
Having had a few Chiglish manuals (Not on VFD's though...) I know how annoying they can be. I've heard a few tales about them being badly worded and difficult to fathom but I guess it depends which one you get.
I did a project at Springfields using those, but only interfaced with them from the DCS system so had very little to do with the drives themselves. They looked OK, pretty much all manufacturers seem to have settled on the same format for their displays/front panel. I quite like the Schneider (optional) larger graphical interface with the large round navigation wheel. Lenze were probably my least favourite in terms of front panel (They had a removable keypad), horrible and confusing menu system, though the software wasn't too bad.That's one of the things I really like about the ABBs I have - meaningful screen, meaningful manual, e.g.:
Also... the 3-phase 415v input are easy to hack to get 415v from 240
Dave H. (the other one)
Looking for a VFD for my pillar drill.
Mitsibushi are excellent, proper industrial inverters. If you can get one that's new or lightly used you won't go far wrong. I'd agree with oversizing if going down the Chinese generic route, but something like the Mitsibushi or (insert any proper industrial inverter make here) then you probably don't need to. A 1.5 kw one for that price is well worth getting.Its a 10 speed drill so I guess I shouldn't really need variable speed but I guess it would be a nice option to save changing belts if its a light job.
I was hoping to keep things around £100 if possible.
0.5hp motor on the drill, I assume there is not much point in overrating the VFD in this instance? I would need another VFD for any new gear I buy down the line anyway and its a personal workshop so will be on a low duty cycle.
I see some really good deals on a Mitisibushi D720S - 1.5KW sub £100 any good reason not to take a punt on one of these?
It's not wrong - though using decent kit should negate the need to do it - the "right" sized vfd should be able to supply 200% of the rated current for a few secs and 150% for a minute or more (depending on make of course). In work it's not often I see a drive much more than 1 size above what the motor is, if at all. I guess at lower power the differences may be magnified.With my first foray into using a VFD, I was advised some years ago by someone at Direct Drives, always to overrate the drive. This was when I was having issues with one of their drives, rated 3/4hp, running my 3/4hp motor.
