Yes! High current+coil=heat.Yes I’m getting there at last ! Yes I plugged the welder in that lead ! Should I have straightened the lead out first ?
You really need to unroll it if you’re using a heavy load like a welder. The cable will be getting warm, and you risk melting the insulation and causing a short. Maybe even a fire if you’re really unlucky.Yes I’m getting there at last ! Yes I plugged the welder in that lead ! Should I have straightened the lead out first ?
Yeah thats a good point actually. When I melted my Dad’s cable it was with a stick welder, but likely plug welding with a mig would be slightly less likely. Still good practice to unwind it thoI can't imagine the welding of a sill into a rusty Ford will be long, full fat, seam welding, so unlikely to be pulling serious current for long enough to over heat to the point of combustion.
Id still use a shorter, straighter, lead though.
Fair point.I can't imagine the welding of a sill into a rusty Ford will be long, full fat, seam welding, so unlikely to be pulling serious current for long enough to over heat to the point of combustion.
Only time I saw it happen was not really an extension. It was a really heavy duty industrial vacuum cleaner with a lot of flex wrapped round the motor on top. Ten minutes use saw it go up in smoke.You really need to unroll it if you’re using a heavy load like a welder. The cable will be getting warm, and you risk melting the insulation and causing a short. Maybe even a fire if you’re really unlucky.
I’ve only burned out one extension lead through not unwinding it - a lesson learned the hard way. The 16 year old me had to own up to buggering up my Dad’s extension lead and he was not impressed. Could have been far worse though…
I've only seen one really bad extension lead, it was a melted mess that had reset in a solid lump. What the hell the user was doing while it was destroying itself is anybody's guess.Only time I saw it happen was not really an extension. It was a really heavy duty industrial vacuum cleaner with a lot of flex wrapped round the motor on top. Ten minutes use saw it go up in smoke.
The van is looking a lot more solid now![]()
I think it's worth weld through, make sure you have proper drain holes too, I can't see them in the replacement outer sills, they are normally swaged into the bottom lip.Hi guys I’m hoping to finally weld my new sill on at weekend after repairing my inner sill and inner wheel arch ! Should I use weld through primer to give protection between the panels or not bother ???
Nice workVan update, sill is welded on ! Just got to grind the welds and do the plug welding on the lip then filler and a final sand then paint ! Rain has stopped play grrrr
