apart from the obvious skill involved it is loverly to see the wood after a truly sharp chisel has been used , pleasure to see.Over the last couple of days we've been out and about in the Pyrenees. The scenery round here is beautiful and we even got to see a golden eagle up extremely close when it flew across in front of us. With all that, I didn't do any more on the box until this morning.
Before doing anything on the box itself, I decided to fix the drawer supports in place permanently:
I really like having the three most useful drawers lying on the bench stretchers so I'm happy to commit to the screw holes now (the supports were originally just held in place with double-sided tape).
Returning to the box, the first thing I did today was chisel the mitred corners using the mitre guide I prepared in the last instalment:
I then relieved all the inside corners of the tails in order to help the joints go together easily:
For the back of the chest, I didn't have any Sycamore that was big enough, so I pulled out a bit of 6 mm ish rough sawn Sweet Chestnut:
After cutting it in half, I planed that on both sides, resulting in a piece about 5 mm thick:
I could then plough some matching grooves and it was nice to be able to use the little plough plane that I found a spot for in one of the drawers. It took a while to get everything set-up: various stops clamped to the bench and the assembly of the plough plane itself, which is packed in pieces in the tool chest. However, once everything was set up, ploughing the four grooves was completed very quickly:
The four side pieces with their grooves:
I'm planning to make this into a box with two drawers. I've brought a piece of 16 mm-ish thick American Black Walnut with me to act as the drawer fronts. Unlike the previous drawer box (which had the dividing "shelf" hidden behind a lip on the lower drawer), I've decided to make the "shelf" visible but to try to grain match it to the drawer fronts. To that end, I marked up a thin-ish strip in the middle of the plank:
After cross-cutting to length, I reinforced the pencil marks...
... and (after taking a deep breath as I was a bit nervous about sawing skew-whiff), I ripped the board into three pieces with the Dozuki:
I was rather pleased with how that went:
The other half of the Sweet Chestnut plank will be used for most of the shelf, but the thinner bit of Walnut will act as a trim to (hopefully) make it look better. Without bothering to try to plane the face sides down at all, I just planed the joining edge straight and square on the two pieces:
Glue was applied...
... and then I got a bit carried away with masking tape:
Once the glue has dried, I'll plane the faces and then trim it to the final size. I'm not going to cut the housing in the case sides until I've planed the shelf to thickness; that way I can be more confident of getting a snug housing joint.
At this point, I realised that I won't be able to finish this drawer box while I'm in France. I hadn't planned what I was going to make very carefully for this trip, just chucking a load of wood in a bag and assuming I'd figure it out when I got here. I did, however, put a load of thin off-cuts of Sycamore in, thinking they would be good for drawer sides. They will be good for drawer sides, but I've made this box quite big as I wanted relatively deep drawers and as such the Sycamore pieces are too narrow to be used for the sides of the two drawers:
I could make the top drawer narrower than the bottom one and continue to make the top drawer with that Sycamore (and sort out the bottom drawer when I get back home) or I could make them both equal and sort both drawers out when I get home. Either way, the box won't be finished while I'm here, but that doesn't really matter - it's still nice to have some woodworking tasks to get on with. I'll have a rummage through the rest of the wood that I brought with me and I may be able to use that Sycamore for something else instead, or alternatively just make (or start making) a completely different box altogether. This is the downside of not planning the boxes I'm going to make in advance!
I love the fact you basically do 99% of your woodwork by hand. Personally I'm all for making my life easier with power tools but the respect I have for those who almost exclusively work by hand is huge!
I want one now, but it would never be as good as yours
Where do you get your timber?
Weird. They appear fine here. They're hosted on my website (to make it easy to share on multiple forums). Can you access https://www.cgtk.co.uk ?That's odd the pictures aren't loading![]()
Depends on where its going in my opinion.I'd be interested in opinions as to whether I should do the same (with walnut feet) on this one or just to leave the box sitting flat on its base.
