The correct switch is a no voltage switch meaning there is no voltage on either of the terminal to the drill when it is off .I replaced the switch on a similar drill with a rocker switch, probably from a Henry vacuum cleaner. Yes there's a risk of it starting if you forget to switch it off after a power cut but that's one I'm willing to take.
Your switch could see the drill motor still live if the wall socket wiring is not correct .
