123hotchef
- Kent
Good to see it is already in use.
Reverse osmosis (RO) is a water purification process that uses a semi-permeable membrane to separate water molecules from other substances. RO applies pressure to overcome osmotic pressure that favors even distributions. RO can remove dissolved or suspended chemical species as well as biological substances (principally bacteria), and is used in industrial processes and the production of potable water. RO retains the solute on the pressurized side of the membrane and the purified solvent passes to the other side. The relative sizes of the various molecules determines what passes through. "Selective" membranes reject large molecules, while accepting smaller molecules (such as solvent molecules, e.g., water).[1]RO Ro Ro yer boat....
Maybe you might tell us what an RO unit is?
I knew that.Reverse osmosis (RO) is a water purification process that uses a semi-permeable membrane to separate water molecules from other substances. RO applies pressure to overcome osmotic pressure that favors even distributions. RO can remove dissolved or suspended chemical species as well as biological substances (principally bacteria), and is used in industrial processes and the production of potable water. RO retains the solute on the pressurized side of the membrane and the purified solvent passes to the other side. The relative sizes of the various molecules determines what passes through. "Selective" membranes reject large molecules, while accepting smaller molecules (such as solvent molecules, e.g., water).[1]
See it’s simpleReverse osmosis (RO) is a water purification process that uses a semi-permeable membrane to separate water molecules from other substances. RO applies pressure to overcome osmotic pressure that favors even distributions. RO can remove dissolved or suspended chemical species as well as biological substances (principally bacteria), and is used in industrial processes and the production of potable water. RO retains the solute on the pressurized side of the membrane and the purified solvent passes to the other side. The relative sizes of the various molecules determines what passes through. "Selective" membranes reject large molecules, while accepting smaller molecules (such as solvent molecules, e.g., water).[1]
That's a tiddler... I look after one that does 350l/s
SWMBO , says the same thing .That's a tiddler... I look after one that does 350l/s
Useful information for the ones wandering about using other batteries on Bosch.Katsu battery converter, from bosch 18v battery to makita tools. View attachment 462129View attachment 462130
That is going to look so stupid sticking out from under the rear bumper of the Vauxhall.Egg shopping today and came back with another bit of Helicopter exhaust!![]()
Where on earth do you buy your eggs!!
That Lidle known helicopter breakers yard RAF Waddington.Where on earth do you buy your eggs!!
PICTURES! (please).A Douglas /AVO wave -winder.
Wonderfully elegant piece of equipment, despite having really required a linear coil winder.....
DAPPH has a video of the walkaround on the thing....PICTURES! (please).
