Arc Tourist
- Wales
Thanks for the tip.If you haven't already look up the "where's the path" website.
I must admit I prefer a paper map to look for interesting routes / places local to where I am.
Injector pump in the background 1st/2nd picture????
I got 2 pairs of the clamps, didn't realise there were 2 kinds, untill I got home and thought hmm they ain't the same.In Aldi today stocking up on dog & cat food when I accidentallywent down the middle aisle....
Yup, no idea how useful they will be I'm already eyeing up a visit to the angle grinderYou mean the ones with the flat plate jaws?
Reverse osmosis (RO) is a water purification process that uses a semi-permeable membrane to separate water molecules from other substances. RO applies pressure to overcome osmotic pressure that favors even distributions. RO can remove dissolved or suspended chemical species as well as biological substances (principally bacteria), and is used in industrial processes and the production of potable water. RO retains the solute on the pressurized side of the membrane and the purified solvent passes to the other side. The relative sizes of the various molecules determines what passes through. "Selective" membranes reject large molecules, while accepting smaller molecules (such as solvent molecules, e.g., water).[1]RO Ro Ro yer boat....
Maybe you might tell us what an RO unit is?
I knew that.Reverse osmosis (RO) is a water purification process that uses a semi-permeable membrane to separate water molecules from other substances. RO applies pressure to overcome osmotic pressure that favors even distributions. RO can remove dissolved or suspended chemical species as well as biological substances (principally bacteria), and is used in industrial processes and the production of potable water. RO retains the solute on the pressurized side of the membrane and the purified solvent passes to the other side. The relative sizes of the various molecules determines what passes through. "Selective" membranes reject large molecules, while accepting smaller molecules (such as solvent molecules, e.g., water).[1]
