What do the two thermostats do? Is there two heaters in there?Exact same model as mine except for the label !
Is one a temperature the heater kicks in and the other when it turns off?What do the two thermostats do? Is there two heaters in there?
One is for melting initially, and the other for 'holding' - the switches selects which is in use.What do the two thermostats do? Is there two heaters in there?
Clever, that will certainly make life easy.One is for melting initially, and the other for 'holding' - the switches selects which is in use.
A few !
I've got just a few cutters to do...
Had a right result and picked up a wax melter for coating tools.
SEBA make the wax pots for Kennedy that they brand up as Red Hot Dip.
Worth looking under candle wax melting regularly if you're after one.
They're mostly specialist cutters, a lot have different radius corners, aluminium and HRSA/Exotic geometry's. That drawer is all carbide. They're also all metric. A lot of mSilly but genuine question, but if you use those why put the protection wax on? Or are they going to be sold on?![]()
Get a CNC, don't need so many sizes of cuttersThey're mostly specialist cutters, a lot have different radius corners, aluminium and HRSA/Exotic geometry's. That drawer is all carbide. They're also all metric. A lot of m
The drawer above is all HSS and full of my more commonly used cutters.
Believe me, I'm still missing the size I always seem to need, it must be another case of n+1. The other day it was 3/16" slot drills I had none of.
That's a bloody good ideaUsed to use one to dip stud ends in where the rest of the assembly was going in concrete. The concrete & asphalt guys could get crap all over and all we had to do was peel off the wax later. Kept the threads lovely and clean.
Want a 10mm keyway but only have a 6mm cutter, not a problem![]()
One day perhapsGet a CNC, don't need so many sizes of cutters
I think I'd have to have a play with one. You're very good with CAD. I'm not so good.I would never have a manual mill again, CNC just so easy. A lathe however, CNC is nice but I would never be without a manual lathe.
