The_Yellow_Ardvark
https://www.death-clock.org/
- Going Away.
Googgle is your best bet.Any pics?
Looks like a Smart & Brown toggle press.Put an advert out for fly press wanted and this came up.
Not sure who made it as the plate has gone. No idea if it’ll do what I need but can always sell it on I suppose. .................................
That’s what I’ve found from google-ing it but glad you agree as well. Trying to find more info but not easy.Looks like a Smart & Brown toggle press.
A seized up ML7.View attachment 277929
That'll come back to life right enoughDon't mov the saddle until you've scraped off the rust. a paint scraper will do it at first. Now that the tailstock has been moved you need to remove it and clean the rust that'll be stuck on the base ways.
A what bath?Plasterer's bath from Toolstation, filled with citric acid, would be my first step.
old bungalow bath. Is that the same, that’s what I’ve seen plasterers use. Can’t be many left of them now.Plasterer's bath from Toolstation, filled with citric acid, would be my first step.
Who would do that to a lathe?![]()
Nice project for those rainy days and well worth the effort.A seized up ML7.View attachment 277929
One of these:A what bath?
I have seen a old enamel bath used in the past. Or a cheep Tesco paddling pool.
It may look worse than it actually is. Maybe you'll get lucky. A friend had an old South Bend lathe, and the ways were just as rusty looking, but they cleaned up very nicely with nothing but a Scotchbrite pad and some oil. A citric acid bath is, as mentioned, another possibility after a thorough degreasing. If you can't find a long enough trough, you could throw together a wooden box and staple in some heavy polyethylene sheet, EPDM, or whatever is resistant to citric acid. I've made such a trough for some long items when I was experimenting with electroplating. It should be a fun project.A seized up ML7.
A what bath?
Way back when, when 35mm film was the best. I once "borrowed a big paddling pool and de rusted a LR chassis, followed by a LR bulkhead
