old bungalow bath. Is that the same, that’s what I’ve seen plasterers use. Can’t be many left of them now.Plasterer's bath from Toolstation, filled with citric acid, would be my first step.
Who would do that to a lathe?![]()
(i.e., someone who had a close encounter of the painful kind with a lathe, perhaps.)Nice project for those rainy days and well worth the effort.A seized up ML7.View attachment 277929
I've restored an old Atlas lathe in similar condition; and I'll bet the price was right too. One of these:A what bath?
I have seen a old enamel bath used in the past. Or a cheep Tesco paddling pool.
It may look worse than it actually is. Maybe you'll get lucky. A friend had an old South Bend lathe, and the ways were just as rusty looking, but they cleaned up very nicely with nothing but a Scotchbrite pad and some oil. A citric acid bath is, as mentioned, another possibility after a thorough degreasing. If you can't find a long enough trough, you could throw together a wooden box and staple in some heavy polyethylene sheet, EPDM, or whatever is resistant to citric acid. I've made such a trough for some long items when I was experimenting with electroplating. It should be a fun project.A seized up ML7.
A what bath?
Way back when, when 35mm film was the best. I once "borrowed a big paddling pool and de rusted a LR chassis, followed by a LR bulkhead
The same way other body shells handle it when dipped by a professional.When I hear of people filling in old swimming pools I think "My Capri could have gone into that!" Not sure how a monocoque body would fair with regards to acid getting trapped between panel joins and leeching out later. Heard some horror stories.
That'll come back to life right enoughDon't mov the saddle until you've scraped off the rust. a paint scraper will do it at first. Now that the tailstock has been moved you need to remove it and clean the rust that'll be stuck on the base ways.
Life is too short for rubbish steak...I only buy mine from the local butcher (who I know very well). He gets a slab of meat out and I tell him how thick I want it. One thing I can't abide is rubbish steak....or good steak cooked badly!Quite bloody dissapointed, thats 90g of solid fat and a much smalled steak than it should beEdit - Cooked steak 98g, so almost half solid fat.
Youd think they have a folder or something at best. All the quarries I’ve worked at are pretty primitive to say the least. You’ll have to post some pics.Mainly chutes, covers and guards as well as general repairs using sheet steel. Sometimes they make steel signs in emergencies.
Got a 1000mm Rubi radial here.Got me a used but only a few times tile cutter to do bigger tiles.
I think this does up to about 600mm but for £50 i would have been mad to turn it down.Got a 1000mm Rubi radial here.
Wouldn't be without it. Just popped it back in the lockup after a busy week tiling.
That's a big one.Got a 1000mm Rubi radial here.
