EddyP
- Northants
If you can stretch to it look at the Milwaukee band file, it's way superior to the B&D offering. I went through two B&D ones over the last 30 years, then I fancied a Milwaukee so it was more mobile and it's fantastic, being able to rotate the arm to whatever angle you need is absolutely brilliant.I'm intending to pick one of those up, I was hoping I might find one in Aldi or Lidl for a bit less money but it looks as if I'll just have to stump up the £50 in B&Q. Obviously that means Lidl will have them a few days later for £15. Presumably the £15 Lidl thing you're talking about is the die grinder - I picked one of those up as well, it's nicer than my Katsu one but mainly because you can run it at different speeds. Power switch is a rocker one, so probably a bit more difficult to find when it needs to be killed off. I must look for a 240V dead mans switch, that's a good suggestion earlier up the thread.
One particular stretch that needs to be ground back lends itself well to the die grinder, though - it's a weld along the inside of a curve just above the swage line on both rear quarters, which are about 5' long each side. Though I imagine the Powerfile held at ninety degrees to the panel would probably do it. This is why I have a load of things for grinding - sometimes the usual one won't get into where the grinds are required, or sometimes it's uncomfortable to hold it that way.
