They are both 14cfmI cant be bothered to look up the stats on them, but its looking much more hopeful!
To be fair I got them both for 500 I had to buy them for that price one is a sip honda gx 160If you have been able to buy both within your budget, no way are they legit. The Clarke one on it's own is over a grand new, and they don't loose their value that much
Please yes that would be very much appreciatedif there both 14cfm they will run a 3.0mm blast jet nicely an airfed mask will pull a fair bit of air and reduce it you could use a decent face mask with cheapo face shield to get you away without getting pepperedi got a fair few given if you want some
working on a job on monday i have so many at home but can probably get some more from therePlease yes that would be very much appreciated
il pm youTo be fair I got them both for 500 I had to buy them for that price one is a sip honda gx 160
Spec
50 Litre
FREE AIR DELIVERY CFM11CFM (312 litres/min)
FREE SPEED RPM1200rpm DOMESTIC2 Years & 10 Year Air Receiver CorrosionMADE INBuilt & Tested By SIP In UKPISTON DISPLACEMENT 16CFM (453 litres/min
NOSIP04444PSI PRESSURE150psi
(10 Bar)
[th width="141.136px"]
[/th]
and the other is clarke pph15c50
Spec
- 15 cfm air displacement from an aluminium twin cylinder air compressor pump with aftercooler
- 50 Litre air receiver tank (CE certified)
- 6.5 HP genuine Honda petrol engine
- 7 Bar (101.5 psi) maximum working pressure
- Built to the latest European Standards specifications, fully tested & certified
- Dimensions (LxWxH) 930 x 400 x 800mm
- Weight: 61kg
Is 3mm the max? On the pot it states 125psi is the max and if it's over to use a regulator what type do I need as I have no clueif there both 14cfm they will run a 3.0mm blast jet nicely an airfed mask will pull a fair bit of air and reduce it you could use a decent face mask with cheapo face shield to get you away without getting pepperedi got a fair few given if you want some
They both run sweetYou've surely been done... Those two compressors are supposed to be nearly £2.4k. You did not get them in working condition for £500.
25cfm will keep up with a 3.0mm jet at 90 psi, i dont bother using a regulator i just run mine at full tank pressureIs 3mm the max? On the pot it states 125psi is the max and if it's over to use a regulator what type do I need as I have no clue
cant even remember what mines set at i dont bother looking
just take of the end of the tankWell, I've got no clue how you managed that, or if they're legit, but hats off to you if so...!
Is it safe to use without a regulator25cfm will keep up with a 3.0mm jet at 90 psi, i dont bother using a regulator i just run mine at full tank pressurecant even remember what mines set at i dont bother looking
Will both compressors be able to keep up with our stop and starting25cfm will keep up with a 3.0mm jet at 90 psi, i dont bother using a regulator i just run mine at full tank pressurecant even remember what mines set at i dont bother looking
expendable scangrit superfine copper slag crushed glass and some do use sandWhat's the best stuff to use for blasting I've been told to stay away from sand what's everyones opinion
Which is safest to useexpendable scangrit superfine copper slag crushed glass and some do use sand![]()
the 1st 2any dust is dangerous to health without a decent mask or used in a cabinet with good extracta or airfed helmet for open blastingWhich is safest to use
Yes.Is it safe to use without a regulator
