dobbslc
- Hertfordshire UK
If you can do your's a month before I have a go it will be much appreciated...I'll be doing something about it when it warms up a bit next year
Have you got any photos of your beast?
No, just for some reason the post on the lap top ended here, and the post on the Tablet went away.@The_Yellow_Ardvark
Have you been on the Pussers?
I was thinking the same, but in reverse!Have you got any photos of your beast?
scrap it
the truck will die of something else
It's a 3rd gen, but the version without the extra plastic trim, no plastic wheelarch bits, and same front brakes as the LN130 (a KZN185G, compared to your KZN185W, I think)Fancy?
Is yours a 2nd gen then?
Ah, the rust might not be too bad then - the bonding should have stopped water ingress from getting right into the channel (rubber seals allow water underneath more easily)......maybe the rust you see is the result of cackhanded screen fitting (a tool run along the side of the screen when fitting the finisher trim maybe)....tool scores the paint and bingo...I've had a Google and it looks like it's bonded in......
