'big ball bearing'? go on then, please telli am goign to be "that guy" and say will a bit of innertube, craft knife and big ball bearing trick not work?
You've just given me an idea.Grind the teeth off a hole saw to make a knife edge, and press it out. A bit of WD40 helps lube it up
I did think innertube but I need the rubber to be fairly flat.i am goign to be "that guy" and say will a bit of innertube, craft knife and big ball bearing trick not work?
I've got some tape cutters, hardened steel round blocks. I'd just need to make a die like you say.Could you turn up a die if it’s only thin?
Piece of round stock with a short round hollow section that’s got an edge turned on it and use a piece of wood to cut on?
Edit - just seen holesaw idea.
For cutting the center out of comething like this, craft knife for the outside then you lay the rubber/gasket material over what ever you need place a big ball bearing over it and give it a decent wallop with a hammer/mallet and it will cut the inside circle out perfectly by nipping it between the 2.'big ball bearing'? go on then, please tell
How critical is it Brad?
Yep. We had one, James Walker. For cutting CNAF and graphite jointingIn my fitting days, on a water treatment plant we used to make all our pipe flange joints (just round rings) using a joint cutter, which was basically a set of Trammell's with a point at one end, as normal, and a blade at the other, I think it was just a standard Stanley blade.
